It is currently Fri Sep 19, 2025 12:56 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 19, 2020 6:10 am
phavriluk wrote:
Most interesting...Fretboard is radiused at 16 inches. This time I bought 'pre-radiused' fretwire, a bunch of one-fret lengths, choosing 12-inch radius so's I could be forcing the ends down when pressing in the frets. I opened the package marked 'pre-radiused(12")', and whaddaya know, the frets are nicely radiused at 16 inches and they're too short to go through the bender, which needs contact at all three wheels. Questions are, this ever happen to anybody, did it matter anyway, and what if it matered what was a resolution that worked?
Thanks!
Returned to the supplier as not what was ordered.
PostPosted: Sat Sep 19, 2020 9:26 am
You don't want to be pressing the ends of the fret down because they will want to pop up at a latter date. You should have the fret bent at a slightly smaller radius than the fretboard so that you have to press the middle of the fret down. That will counteract the lifting fret end tendency.
PostPosted: Mon Sep 21, 2020 9:22 am
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
jfmckenna wrote:
Ed Haney wrote:
I use HHG and press the frets in with an arbor press (modified Harbor Freight arbor here: https://www.harborfreight.com/search?q=arbor%20press which was about $20 a few years ago when I bought it. I drilled out the end of the plunger and installed the Stew Mac fret press caul here: https://www.stewmac.com/luthier-tools-a ... serts.html ) I press in all the frets in the fretboard before gluing the board on the neck. So I know the fretboard is straight, not back bowed, when it is glued down.
I don't have any dents in the fretboard anymore from an inaccurate hammer blow or frets popping up on one side or another when using the press. Among others, Dan E.'s book is a good resource IMHO.
Do you fret the fretboard then glue it to the neck or are you using that setup on the whole neck?
Also do you find that using this method you have to do less fret leveling?
Users browsing this forum: TimAllen and 44 guests
